Slow response in Revit 2018.3.3 When moving walls
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
omushahwar
405 Aufrufe, 1 Antwort
We have a couple users who with Bim360 models Revit is extremely slow. A couple walls they click just lock up the program for up to 20 minutes before they can move it. There is a lot of lag.
Other members of the team work fine and can move the same elements without issue. On the same machines 2020 works fine in bim360, as do non bim360 files in Revit 2018.3.3
I have removed all addins reinstalled updated drivers but the issue remains. Any thoughts on what could be causing the lag?
1 ANTWORT 1
Nachricht 2 von 2
omushahwar
als Antwort auf: omushahwar
In case anyone else is running into this issue.
Uninstall the fabrication module
Uninstall the precast module
Then clear the cache
Removing both of these plugins really helped speed up Revit 2018.3 .3 with bim360
