Slow Network Connection: Can it cause File error in Central file during syncing
2 ANTWORTEN 2
Nachricht 1 von 3
justin_cruz
745 Aufrufe, 2 Antworten
Is it possible for a Office network problem or something like Network slowdown, to affect file syncing to the Central file?
or even worse cause the Central file to be corrupted?
2 ANTWORTEN 2
Nachricht 2 von 3
sureshchotrani
als Antwort auf: justin_cruz
@justin_cruz you are correct while using workshared method any type of slow network can cause Revit file corrupt.
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
Nachricht 3 von 3
Viveka_CD
Hi @justin_cruz
I just wanted to follow up here, any progress on this issue?
Working in a Revit model involves interacting with many systems, and if any one (or more) of those systems has slow performance, the entire experience in Revit can be slowed down. See HERE and HERE for more information.
See similar discussion HERE
Please mark any posts that help with "Accept as Solution" and thanks!
