Is it possible for a Office network problem or something like Network slowdown, to affect file syncing to the Central file?
or even worse cause the Central file to be corrupted?
@justin_cruz you are correct while using workshared method any type of slow network can cause Revit file corrupt.
Hi @justin_cruz
I just wanted to follow up here, any progress on this issue?
Working in a Revit model involves interacting with many systems, and if any one (or more) of those systems has slow performance, the entire experience in Revit can be slowed down. See HERE and HERE for more information.
See similar discussion HERE
Please mark any posts that help with "Accept as Solution" and thanks!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
