slopped gutter
5 ANTWORTEN 5
Nachricht 1 von 6
787 Aufrufe, 5 Antworten
slopped gutter
I need to created a sloped gutter (the roof is sloped to one side), and I want to create a gutter that is sloped too (this side is not sloped) with a drainage at the end.
Is it possible?
Amit
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
...Use Fascia Tool.
...Use In-Place Sweep.
Nachricht 3 von 6
Nachricht 4 von 6
Do you solved this?? Using a fascia or model tool maybe don't be usefull to calculate the materials. I think there must be a solution using gutter tools.
Nachricht 5 von 6
Why is using a fascia or an in-place model not useful to calculate the materials?
Nachricht 6 von 6
martijn_pater
@Anonymous wrote:
...there must be a solution using gutter tools.
No, there is no solution using gutter tools (that I know of anyway). Perhaps start a new thread once you've modeled it as fascia/in-place model called "How do I calculate the materials for an in-place model/fascia gutter"? :zwinkerndes_Gesicht:
FWIW: actually I might just avoid the gutter tool alltogether if you know you will encounter this situation in a project, for future reference, and then do those as line-based generic model with subcat gutter in example, just a suggestion though... #notabigfanoftheguttertool...
