Slopes roof window and roof wrapping
4 ANTWORTEN 4
Nachricht 1 von 5
mairh_tsek
628 Aufrufe, 4 Antworten
Hello all,
I want to create a roof window with slope and the roof to wrap in the window place.
I create a roofprint and a slope glazing roof for the windows. Each time that I join the two roofs I dont take the result that I need.
I want the two layers of my roof by footprint (concrete-green colour, and insulation-bleu colour, to wrap vertically.
I attache an revit example.
My questions are:
1. Which is the correct way to create a window with slope?
2. How I can wrap the roof in the window place?
Any idea will be helpful.
Thank you in advance!
4 ANTWORTEN 4
Nachricht 2 von 5
GHASEM_ARIYANI
als Antwort auf: mairh_tsek
Hello @mairh_tsek
The Wrap feature does not work in Section, You can use the Cut Profile tool, But consider this tool only in the current view and it also does not display the schedule.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
Nachricht 3 von 5
mairh_tsek
als Antwort auf: GHASEM_ARIYANI
@GHASEM_ARIYANI ,
Thank you for your answer.How you cut it vertically? I am trying to do the same but I get this error(image 1).
I did a second approach creating  walls and after the glazing roof but it seems that the roof goes in the walls (see image 2)
Nachricht 4 von 5
GHASEM_ARIYANI
Hello @mairh_tsek
Please see below link. I hope to help you.
https://knowledge.autodesk.com/community/screencast/9fc04b0b-35df-4d4c-93f6-ff9f5e648191
Nachricht 5 von 5
Use the Vertical Opening Tool on the Architectural Tab
