Sloped Wall Foundation
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
3199 Aufrufe, 4 Antworten
I want to get the same Wall Foundation as the wall in the background (See photo below), also for the wall in the foreground.
Thanks in advance.
4 ANTWORTEN 4
Nachricht 2 von 5
bimscape
als Antwort auf: Anonymous
I know this doesn't specifically answer you question with regards to modelling it in Revit, but I may I ask how your sloped foundation is going to be cast on site???
Kind regards,
Ian
Author of The Complete Beginners' Guide to Autodesk Revit Architecture (free online course)
Nachricht 3 von 5
cbcarch
I would suggest using a stepped footing--perhaps use separate walls which vary in height, and the attach the footing to the bottom of each stepped wall.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 4 von 5
als Antwort auf: bimscape
It is certainly not like that. We will be having different heights and stepped foundation.
But I wanted to go fast now, and I was just wondering if it was possible to sort of "rehost" the foundation.
Nachricht 5 von 5
cbcarch
Yes,
There is the "fast way" and the "correct way".
Doing the stepped walls really doesn't take that long.
Plus you would need to come back later and fix it--might as well do it right the first time.
Cliff B. Collins
