Sloped Stringer in stair and I can't figure out how to fix it.
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
Jason_S
521 Aufrufe, 3 Antworten
Revit 2018.2.   The stringer in this one stair is sloped and I can't for the life of me figure out how to change it.   I tried to adjust the boundary lines. took the stringers out and put them back in.  The stair is drawing by boundary lines, and riser lines.  Thanks for the help.
3 ANTWORTEN 3
Nachricht 2 von 4
SteveKStafford
als Antwort auf: Jason_S
Edit the sketch - convert to sketch first if necessary. Select each boundary (one at a time) and change the setting to Flat instead of Auto (see this blog post if it helps).
Steve Stafford
Nachricht 3 von 4
Did you break the boundary line at the landing?
Nachricht 4 von 4
Jason_S
als Antwort auf: SteveKStafford
Steve,
Thank you very much.  I missed that entirely.  You solved my problem.
Thanks again.
