I have sloped columns all over my model (a family I created myself). I want simple pin connections on the top and bottom ends of my column, so I created a generic model family with instance parameters that I then associate to the column family when they are placed in there. This works well in the family, flexing through every configuration... until loaded into the model. In the model, all the end caps are off-axis to the column, like there is a rounding error in the angle. Eventually, I will model a hole and pin, plus use the same generic model on the top and bottom to fix the column to the floor/ceiling or other columns. But there's not much point yet when it doesn't match rotation.
I am an architecture student - these just need to look correct in 3D views for my renders, and all orthographic views.
Any help is much appreciated!
p.s. I suspect that the placed column is not updating its slope parameter when I increase/decrease its height - it is just using the one calculated in the family with the default dimensions, not the instance's actual dimensions.
