Hallo
I am new to roof by mass, I have a problem in the roof connection between the two parts of the mass roof as shown in the attached sketch can someone tell me how to solve this connection problem .
Gambrel is going to be hard with Roof by Face. Play around with the "Pick Faces Location" Property.
...or, Roof by Extrusion:
Hallo, thank you for the reply. it is hard to due by extrusion as the walls are curved, will try to play with the faces but I failed so far.
sometimes using Wall by face works much better then Roof by Face. I often use this option when making domes and other steep roofs...
Constantin Stroescu
