We have a Revit model that is already started (version 2020.2) that contains an interesting wall system, see attached screen shot. Is there a way to slope only the vertical panels (rotate from their base point at the foundation), and nothing else? We would want the panels to slope outward. I have seen videos of "creating" sloped walls from the start, but not rotating a wall, already modeled, from its base for example. The vertical panels I'm trying to rotate/slope outward are a curtain wall system.
Gelöst! Gehe zur Lösung
Gelöst von cbcarch. Gehe zur Lösung
You can do it in Revit 2021.
Can you post that screenshot you mentioned above?
I'm initially thinking that this may be a job for Wall by [Mass] Face.
