slightly off square off axis model fix needed
1 ANTWORT 1
Nachricht 1 von 2
322 Aufrufe, 1 Antwort
I have a model that parts of it are slightly off square off axis from drawing over an Autocad file.
Is there a fix … Dimensioning this model is a mess …
The workaround is aligning thigs to reference planes
1 ANTWORT 1
Nachricht 2 von 2
RDAOU
als Antwort auf: Anonymous
@Anonymous
  1. How does the original CAD looks like? does it have those off axis element or that happened only in Revit after performing some command like rotate or move...
  2. How did you import the CAD file?
  3. Did you explode it?
  4. Did you check the option "correct lines that are slightly off axis"
Did you check the below link if it is of any help
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Revit-Troubleshooting/files/GUID-E8BF9268-4C26-439E-BB27-50EBF3638D3A-htm.html
