Sliding Folding Louvered Door Panel With Operable Louvers Panel Family
4 ANTWORTEN 4
Nachricht 1 von 5
Kumarkapadia
2575 Aufrufe, 4 Antworten
Hello Everyone,
This is with reference to thread -
https://forums.autodesk.com/t5/revit-architecture-forum/rotation-angle-for-louvers-of-door-panel/m-p...
With You'll help i was finally able to achieve what i wanted, so hereby posting the family with all the editable parameters where in u can edit the family (panels on right and left) in sequel of 3 with its rotation angle
This is for all entire community and all the revit users who might be right now or may be in future might look to achieve this or may be something similar
Thank you all
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Kumarkapadia
Nice job.  What does "Louver Spacing" do?
Nachricht 3 von 5
Kumarkapadia
als Antwort auf: barthbradley
@barthbradleySir Actually that parameter is not relevant in Main Family but if u select that family then u will see that there are multiple nested families within which will take u to FAMILY >>> HORIZONTAL LOUVER LINE BASE where in the louver is arrayed in reference to 2 parameters  H.Blade Panel Height / H.Blade Spacing which will decide ur number of louvers which u can have it according to ur design which is right now 6" but u can make it in multiple of 3" or 4" or whatever dimension u want for which u will have to change the panel height and lock the arrayed louver to it...hope that make sense ?
Nachricht 4 von 5
jklei41
This is amazing!! Any way to make it have 4 panels on each side? I tried, but anything above 3 panels per side does not show up
Nachricht 5 von 5
azad.Nanva
als Antwort auf: jklei41
https://forums.autodesk.com/t5/revit-architecture-forum/louvers-panel-family-four-parts/td-p/1307113...
