There should be a screen shot of the wall in question.
Is this the screenshot you meant to post on your other thread? If so, you should post it to your other thread. It won't make much sense here without some explanation. But, if I understand correctly from what you said on your other thread, you are wanting to slant the facade walls; right? If so, I'd use the Walls by [Mass] Face approach.
Hi! do you want to slant that wall and its components?
Gustavo Ubriaco Contreras
