Good evening Revit users,
I created a slanted wall, and behind the slanted wall is a window. I'm trying to cut an opening in the slanted wall. When I select the slanted wall I can't edit the profile, BUT when I change it back to vertical and create the opening THEN try to change it to slanted, I get a error warning stating "A wall with an edited profile must have a vertical cross section" What does that mean, please? It's probably something simple.
I have attached pics on the steps and the error.
Any and all assistance would be helpful.
Thanks Brian
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
@brianwclayton1969 wrote:I get a error warning stating "A wall with an edited profile must have a vertical cross section" What does that mean, please?
You can cut a slanted wall with a window and choose the window to be slanted or vertical.
If you only need the opening then use an opening family (right one above).
THANKS SO MUCH!!! The Window opening worked it was awesome!!
Just what I needed.
Brian
