I plan add louver using curtain wall in a slanted wall, a glass curtain wall is already there and I need to make them flush, since it is slanted wall, so it is hard to do it. Is there a way to make them on the same plane, " Align " doesn't work.
Use slope glazing or create massing and apply curtainwall to slope massing.
I can make the slanted wall vertical and add the curtain wall then make them slanted again, but I would get error messages and I might have to add curtain grids again. Just don't want to avoid that. But if no better solution, that is the method I will use.
