Is it possible to slant a wall at 45 degrees, but set the rotation axis to be curved (red dotted line in images below). I have created a roof structure using model in place, creating a sweep and then a series of void extrusions. I am now trying to create the skylight structure above by creating a curtain wall which I can then rotate 45 degrees along the curve of the roof. Please see images attached. The issue is that when I rotate the wall the plane by which it rotates is flat rather than being able to choose a curve. I wondered if there was a way to set the rotation plane along a curve.
Fin
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Can you post with an example showing me how you've done it. Thanks
See example of what I get when I try to attached Top/Base
I would create a mass family
Once you load it in, you would use roof by face & curtain system by face
I would do it via a Mass. Wall by [Mass] Face. Be a heck of alot easier.
@johnsonf69KJ7 wrote:Can you post with an example showing me how you've done it. Thanks
I'm not clear what is going on in that screenshot. Post the File here.
