Hi Good day,
I'm currently working on a project with involves making a material legend for my floor.
The way I did was making a 10mm slab on top of my current slab then dividing it into parts and putting up a material in every parts.
I made also a template, which I named OVERALL (1:350, course) and PUBLISH (1:50, course)
I made the parts in my Overall plan, my problem is that the parts with hatch doesn't show up in my Publish plan.
Just for experiment I tried making my PUBLISH drawings in to a OVERALL template but still it doesn't show up the parts with hatch.
I also tried making some callout to check the detail but still it failed to show up.
Thank you in adavance.
Actually my Overall & Publish have the same view range. I can select the slab but I cannot select the parts in publish.
Just checked my visibility graphic the parts are turned off at the Publish template.
Never thought it has a category,
Thanks sir ToanDN
