I'm using Revit 2022.1 and I want to copy generic annotations of a slab opennig to a slab on a 3.floor. I did the same thing for the 40 openinngs on the 2.floor. Now the situation is the same, but after pasting with the option: align to a currant view, a messege pops up, that the annotation can't find its host (void cutting the slab). When I try to copy annotation form 1.floor to the 2. floor it still works. The problematic openinng is precisely on the same spot as on the floor below. I can even copy the dimesnisons, so that must mean, that the opennig is on the same spot. Any ideas what is causing this problem?
Thanks for any suggestions
Lukas
does the opening "Void" extend past the 3rd floor level or only "up to" the 3rd floor level? I have seen issues with some things where if they don't cross the level it doesn't recognize it.
Howard Munsell
So basically, what you are saying is that 40 worked and one failed? Post the file here for us to test.
