This worked for me before. Why won't the slab edge move with the floor?
Solved by barthbradley. Go to Solution.
Why not use a slope arrow instead of Modify Sub-Elements?
...or are you wanting the Slab Edge to change height as it follows the slope? If so, Model the Slab Edge as a Wall and use Attach Top/Base Tool.
I tried modeling using slope arrow. Still can't select an edge for slab edge.
