Slab Edge filter cut lines greyed out
2 ANTWORTEN 2
Nachricht 1 von 3
grantkjones
1534 Aufrufe, 2 Antworten
Hi, I have created a filter for my slab edges when description = value.  when I apply the filter to my section view, I cant select anything cut ie lines or patterns.  Only projection Surface.  is this normal behaviour?  I would like to create different line styles for different slab edges based on the value in the description field using a filter.  is this possible?
Tags (2)
Beschriftungen (1)
2 ANTWORTEN 2
Nachricht 2 von 3
I just went through the filter setup process and got the same results.  It appears we can only change the Cut Line and Pattern at the V/G Override Model Category level.  Based on what I can see of our ability to control, what you are looking to do is not achievable, without doing it manually using the Linework tool.
Nachricht 3 von 3
Joey_JM
als Antwort auf: grantkjones
I just ran into this same limitation. Depending on the application, a possible workaround is to make the filter multi-category by pairing the slab edge with at least one other 3d category (I included the floors category) and then the cut lines/patterns can be overriden.
