Good afternoon. I need to modifiy the default slab edge dimension to increase the depth of it. Please see attached. Is there any solution to this?tHANKS
Thanks but I cannot pick up from the construction profile same as he is doing in the tutorial, I don't have these options available..
Not sure how you do not have these options available... Please explain... Are you Revit user or is this your first time using the software? Sorry, just trying to get a feel for your current expertise with the software to provide a better solution.
You need to modify the profile used to produce to the Slab Edge. When you select the Edge, you are given the properties of that object. If you scroll down the list of families to Profiles > Slab Edge-Thickened, right click and choose Edit.
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
I am a beginner revit user and I can't find the edit. Please see an image attached of my screen.
@Anonymous
Again another question reposted although it was previously clarified how to creat the slab edge and how to add a custom profile for that edge which can be later adjusted to your liking....
Quote from your previous POST:
The slabs (split levels - see the isolated 3D view at the end of screencast) to which your walls got attached to, should not be modeled that way.
Watch the screencast again...and make sure to mark the helpful replies as solutions so you may find them in the future easily!!!
You need to create a new Profile Family with the desired dimensions.
This will then be available as an option when you click on the Profile dropdown in the Type Properties of the Slab Edge.
