Slab edge at the tank
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
651 Aufrufe, 8 Antworten
Capture.PNGHow to model this conner slad and we can takeoff material? Please help me
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: Anonymous
Model the main slab with a hole and add slab edge around the hole. The model the pit as a separate slab. Join them.
Nachricht 3 von 9
als Antwort auf: ToanDN
I know this step to model but when i takeoff material then it can not creat schedule about volumeCapture.PNG
Nachricht 4 von 9
Are you saying a material takeoff schedule doesn't read the volume of the slab edges?
Nachricht 5 von 9
yep. This is problem for me....do you have skype or viber? would you like to connect with me?
Nachricht 6 von 9
Did you create a multi category material takeoff schedule or a floor material takeoff? It should be a multicategory. And no, I am in bed and not wishing to talk via any social app right now.
Nachricht 7 von 9
I still not make takeoff material at slab edge :enttäuschtes_Gesicht:
Nachricht 8 von 9
Create Parts from the Slab Edge then use a multi-category material takeoff schedule and you will get it.
Nachricht 9 von 9
I did not creat part therefore i can not takeoff material. I have resolve this problem. Thank you much.
And i have a problem to model this conner at the tank. Revit structure is difficult to model some elements that is big detail. I use to revit 3 years but i still miss some difficults about structure such as takeoff material, reinforcement, drawing detail..Capture.PNG
