Hallo All!
I'm fighting with tags placement. Is there a way to force skylight tag to place it in the center of the skylight? I was convinced that the intersection of origin reference planes indicates the tag placement - it appears that it does not work this way... unfortunately. Or maybe I'm missing something?
In the skylight family I have set the reference planes which intersect in the center as origin. Facts:
Do I need to agree with Revit (logicless) limitations, or am I doing something wrong? The issue is to have a leaderless skylight tag placed in the center of the skylight. Any ideas?
Kind regards!
Bartek
Solved by ToanDN. Go to Solution.
I opened it and couldn't work out the issue either...
As a temporary solution, you could always create a TAG that has a different origin...
François-gabriel
Francois-Gabriel Perraudin
BIM management and coaching
Thank You for suggestion. By a tag with "different origin" You meant a tag with a label origin offset in it? I could create one, bu:
So to have a tag precisely in the center of the skylight I would need to create as many window tag families as many skylight dimensions types would occur, and multiplied with number of drawing scales I were up to use in a project..
Or did You meant something else?
Bartek
@bartek.calka you are right, you don't want to do that.
How about giving the label an offset (as @FGPerraudin suggested) and control this by a distance parameter? Adding an invisible line to the label text and grouping them would allow you to control the position. When you drop the tag in place, go into Edit and change the value of the parameter. Definitely beats having to move tags individually, or create bazagazillion tags for each skylight.
Window category always hosts Window Tag outside of the Exterior face on Plan view. That's for the Tags not overlapping the Windows when placed without a leader. So, skylights under Window category inherit this behavior and that's what you are experiencing. If you can change the skylight family to any other category (Door, Generic Model, etc...), the Tag will be placed on the center.
Thank You @ToanDN, it explains a lot:)
So it's a bit workaround, but I think nothing better can be done. I'v...
...and it works fine. See attachement.
Bartek
Adding an invisible line to the text of the label and grouping them will allow you to control the position. When you leave the tag in place, go to Edit and change the parameter value. If you wanna know how to measure skylight see here: https://rvprofy.com/how-to-measure-rv-skylight/
