AnzeigenĀ Ā nurĀ  | Stattdessen suchen nachĀ
Meintest du:Ā
SKP file disappearing when scaled up
8 ANTWORTEN 8
Nachricht 1 von 9
StephaniePhillips2269
505 Aufrufe, 8 Antworten
Got a issue importing a SKP file, Has imported correctly and is showing both in 3d and 2d floor plans but is scaled incorrectly and when scaled up it disappears. How do i scale it without it disappearing ?
8 ANTWORTEN 8
Nachricht 2 von 9
How are you scaling it?
Nachricht 3 von 9
Have scaled multiple ways but it almost seams that as soon as it gets bigger that the box it imports in it disappears
Nachricht 4 von 9
Multiple ways?  What ways? I can only think of two ways, right off hand.
Nachricht 5 von 9
Have scaled through Modify scale tool and through type property changing the import scale
Nachricht 6 von 9
What Scale Factor are you entering?
Nachricht 7 von 9
Let us have a look at the SKP.
Nachricht 8 von 9
it says scaled 1:1mm when imported but is actually 1:1000 and when changed to be correct units and scale factor it dissaspaires out of the import scope box
Nachricht 9 von 9
So your are basically describing this?:
Before:
After:
In Foren verƶffentlichen
