Sketch Lines are halftone
2 ANTWORTEN 2
Nachricht 1 von 3
joanna
1324 Aufrufe, 2 Antworten
When I edit boundaries for floors, the sketch lines show up halftone, making it difficult to work. They look light, transparent pink rather than magenta. The lines show the normal, deep opaque magenta color when i'm editing a wall profile or ceiling boundary. Is there a way to fix this?
2 ANTWORTEN 2
Nachricht 2 von 3
Viveka_CD
als Antwort auf: joanna
Hi @joanna
I see that you are visiting as a new member! Welcome to the Autodesk community!Smiley (fröhlich)
  • Can you check if the Discipline settings for that view (Architectural/ coordination) has not been changed?
  • Did you use different walls for this level? Check if this happens on all other levels.
  • Is this floor plan from a linked file? Then please check your visibility graphics for the wall category of that linked file.
  • Is your phase filter set to default new construction for that view?
Let us know if you were able to resolve our issue.
Nachricht 3 von 3
mbdot00
Go to:
Manage>Additional Settings>Line Styles>Lines (expand +)> <Sketch>
Adjust line weight, colour and pattern accordingly.
:leicht_lächelndes_Gesicht:
