Sizing Walls
Sizing Walls
aadamsA2F2Z
Message 1 of 21
Sizing Walls
aadamsA2F2Z
Hello All,
I had modeled my design in autocad before I started designing it in revit. I had all the dimensions perfect in autocad.  I am teaching myself revit and started doing the floorplan using the wall function in revit. After I have spent over 50 hours on this trying to figure out all of revits functions, I realized that the dimesioning does not work the same as auotcad, so now all of my overall dimensions are off. For example, I wanted a wall to be exactly 15' 4" from the outside of the building, since I am using 8" masonry in revit changes the dimension to 16'-8 1/4". This is so frustrating because now my building does not fit into my property lines, any advice on what I am doing wrong?
I have determined that it is because it measures from the centerline, so any advice on how to account for this or change the setting?
Even in this picture, I made this wall 15'4 and it changed it to 15'-11 3/8
Replies (20)
Message 2 of 21
Are you talking about the Temporary Dimensions?
Read this:
Specify Temporary Dimension Settings | Revit | Autodesk Knowledge Network
...also, drill down into this Link:
Temporary Dimensions | Revit | Autodesk Knowledge Network
...or are you could be talking about the Unit Precision that the Dimension Type is using?
Message 3 of 21
aadamsA2F2Z
no it is not a temporary dimension, it is the actual dimension that i typed in when i made the wall
Message 4 of 21
aadamsA2F2Z
Autocad vs Revit. The Autocad dimensions are what I am trying to achieve, but when I type in those numbers when doing the walls I get these dimensions instead
Message 5 of 21
I don't understand. Are you saying the walls in Revit are exactly the same as the walls in AutoCAD, but that they are not showing the same dimensions. I don't see how that is possible. Post the RVT and DWG here as an Attachment to a Reply Post.
Message 6 of 21
aadamsA2F2Z
Yes, when drawing the walls I put in 15'4 and it spits out the 16' length when I start joining the other walls to it, and okay I will post a reference file.
Message 7 of 21
aadamsA2F2Z
here is the files
Message 8 of 21
aadamsA2F2Z
it did not look like the attachments were there when i posted.
Message 9 of 21
They are not the same.
Here's your DWG Linked into Revit.  The DWG is RED in the screenshot.
Message 10 of 21
aadamsA2F2Z
i see that they are not the same, but i dont understand why when i type the same dimensions from my autocad into revit that they do not come out the same.
Message 11 of 21
aadamsA2F2Z
i literally will type in 15'4 and it changes it and i dont know why
Message 12 of 21
When you "type the dimensions"?
Like this?
As you can see in the above screenshot, I'm having no issues "typing" in dimension value.
Message 13 of 21
aadamsA2F2Z
like this, when i activate the 'WA' command and put in a new wall link
Message 14 of 21
RDAOU
@aadamsA2F2Z
Looking at your Revit and your dwg...it appears that you went flat out on walls placing them using Location Line at wall Centerline...Next time you are placing walls chains by typing in Dimensions (Similar to what you would do in Autocad)...it might be more convenient to .
  1. use Location Line at Finish Face
  2. When you type in length, type in 15 space 4 ... no need for the ' & "
It is sad that you will have to resize all at this stage
Message 15 of 21
aadamsA2F2Z
yes i believe this is the problem. it is very sad, I am brand new to this program and teaching it to myself. such a big learning curve. about 50 hrs of my life down the drain, but good learning lesson. thank you so much
Message 16 of 21
Just as an FYI: these symbols indicate the exterior face of the wall (which is currently oriented towards the interior). If you press it, you can change the wall's  orientation.
Message 17 of 21
aadamsA2F2Z
i just tried doing this, and all the dimensions were still messed up. I do not know what I am doing wrong
Message 18 of 21
RDAOU
What did you do?...what measurement are you punching in? and what are the project units for Length?
Message 19 of 21
aadamsA2F2Z
i did exterior face like you suggested and I used the dimensions from my autocad, and it just does not have the same dimensions. I can try inserting a video of what i am doing
Message 20 of 21
RDAOU
@aadamsA2F2Z
If you are hitting Space bar somewhere in between...you will be flipping the exterior to the inside (Space is Autocad for Enter ... Revit it is Enter for Enter)...so when you hit spacebar, watch out to witch side the Exterior Face of the wall is oriented
