size of triangle
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
607 Aufrufe, 9 Antworten
size of triangle
Hello. Is ot possible to change the size of the triangle? Thanks a lot!!!!
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: Anonymous
Nachricht 3 von 10
Edit the Level Head family and re-size it.  You know it's Annotative. It scales with the View Scale.
Nachricht 4 von 10
als Antwort auf: barthbradley
But, how do I edit the the head level family?
Nachricht 5 von 10
Go to your project browser, under families find the name of your level head family, right click and Edit.
Nachricht 6 von 10
Edit type and find the symbol, then edit it.
Nachricht 7 von 10
als Antwort auf: ToanDN
No edit option
Nachricht 8 von 10
Select the family, not teh type.
Nachricht 9 von 10
That would be next to impossible.
Post your file here.
Nachricht 10 von 10
Also, check your view scale, set your view to the scale intended to show on sheet and see if the symbol and text size is okay before changing the family.
