Site topo from DWG Not working R19
When I try to select the imported DWG site file, I cannot.  Revit doesn't seem to see it there.  It is 3d.  I can see the different levels.  Is there a known issue?  What is likely causing this.
Nardo
ennujozlagam
What do you mean?can you explain more. It could be the site plan is pinned, unpinned it or go to your lower left corner of your screen and look for bulb icon and activate it could be hidden in the view, unhide it. And see if helps. Thanks
Check to see if you have a selection restriction going on?  Look the condition of those check boxes in the drop-down dialog box under "Modify" button.
Betcha "Select Pinned Elements" is unchecked.
More than likely it is pinned, and you have Select Pinned Elements disabled in the lower right corner of the screen.
Thanks for the suggestions.  Nothing seemed to work.  I had deleted layers that I figured were not Topo.  There were over 100 layers.  Maybe that was the problem.  I reloaded the CAD as a DXF and it worked.  I still eliminated many layers, but it worked.
Thanks for trying to help out.
Nardo
