Site Plan
6 ANTWORTEN 6
Nachricht 1 von 7
jfjacques
418 Aufrufe, 6 Antworten
Site Plan
First off, I want to find my survey point. It's on in VG, but doesn't show up in the model in plan. It also doesn't show yp if I play with View Range.
It shows up in section though.
WTF?
As you can see the house does not align with plot lines. I want to align it in the plot line- I'm assuming the best way to do this is to rotate the survey point?
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: jfjacques
Just rotate the Property Lines.  I ain't rocket science.
Nachricht 3 von 7
jfjacques
als Antwort auf: barthbradley
????Rotating the property lines changes their orientation.
S 31 W becomes N 58 E etc...
Nachricht 4 von 7
jfjacques
Also why isn't the survey point showing up>?
Nachricht 5 von 7
The Survey Point has nothing to do with it.  Now. if you want to change the Angle to True North, that is done through the Project Base Point.  But, that is not going to rotate the Property Lines. You need to use the Rotate Tool to rotate the Property Lines.
Nachricht 6 von 7
jfjacques
So why would neither the SP and the PBP not be showing up?
If I rotate the PBP and then the property lines, they should keep the right bearing.
Nachricht 7 von 7
Here's a list of things to check when you can't find stuff:
Missing Something in a Revit View? 33 Steps to Find Stuff | Ideate Inc
