Site Embankment and Contours
2 ANTWORTEN 2
Nachricht 1 von 3
619 Aufrufe, 2 Antworten
Good day
I need some help with my plant topo surface... I Created a JPG file from an underground CAD Design and inserted it to draw my contours in Revit... When in Site view there are only about 2 contours visible in view after hiding the JPG... apart from this my model differs from the SketchUp model I received as Concept for the plant... So the SketchUp model is not always accurate but my embankment does not even come close to the 4.5M in the SketchUp file... (Thinking whoever did the SketchUp might make a mistake, or maybe I'm missing something...) If someone can help me with the topo visibility it would be great...
thasjansen_1-1587495056549.pngthasjansen_2-1587495089945.pngthasjansen_3-1587495110760.pngthasjansen_4-1587495126294.pngthasjansen_5-1587495129035.png
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
I'm not understanding anything from these screenshots. Maybe posting your file would be the best thing.
Nachricht 3 von 3
als Antwort auf: barthbradley
Hi B
https://www.dropbox.com/sh/dmp01zm38izpc1s/AACrXMQwMwWrtFgZMniyTYz7a?dl=0
So my main issue is that my design doesn't match the SketchUp image in terms of the embankment hight. But I'm thinking the Sketchup might be wrong because I used actual information provided to do the Topo but because I'm not seeing the contour lines on my Rivit model I might have done something wrong as well...?
