Site Designer Families
2 ANTWORTEN 2
Nachricht 1 von 3
IMCornish
636 Aufrufe, 2 Antworten
I have taken the plunge and started to use Site Designer!  Started to regret it but think I have a better understanding of it now, however, the families available are very restricted and when I wished to create a tarmacadam (asphalt) surface leading to two houses on a small development I found that I only had enormous roads to choose from.  I then thought I would look at the Site Designer families and create some of my own to meet my needs using the existing as starting points and editing them.  Consequently I found that the existing families contain absolutely no data at all, just a load of empty views!  I am now stumped and wonder if a Site Designer is so limited and also how does it work with empty families?
Does anyone know or can help please?
Andrew Robertson
Chartered Architect
Robertson Partnership
Truro. UK
Tags (1)
2 ANTWORTEN 2
Nachricht 2 von 3
FarhanUddinShaikh
als Antwort auf: IMCornish
Hi, Site designer causes difficulties, Parameter are responsible on that planes as wel.
Nachricht 3 von 3
lostagain
I'm only one step ahead of you, but to modify site designer families, go to site designer tool > family managers > (select the family type). From there, you can modify families. Now, how to modify the families? Who knows, there seems to be no instructions in the help system.
