Site boundary lines distorted
So for my ground floor, In the view range, I set View Depth to unconnected so the contour lines on my site would show as well. However, the style and color of the site boundary lines changed. It was red dash lines.Now it is connected What can I do?
Thank you very much for the help.
The original one: view from base lineThe original one: view from base lineHere  the boundary lines are distorted.Here the boundary lines are distorted.black line.
That line work is controlled through the Subcategories under Topography in Visibility and Graphics and Object Styles. Have you gone there?
@barthbradley
Thank you for your response.
Yes, I have been there. It doesn't seem like there is an option for the boundary lines, or something like that. I have tried to play with it, but nothing changed.
I tried to to show the contour line through the "underlay" in floor plan properties, and put the depth to unlimited, but then I can see the footings of the columns under the building.
Underlay?! Well that's a different animal. Go to Additional Settings under Manage Tab to change the Halftone/Underlay appearance.
I tried, it sort of helps, but I think it is better to use. I think I might have to just edit the boundary line after wards.
Thank you!
Dang! I thought that was a shoe-in for the Solution Credit. No? Still doesn't float your boat? I guess I need to examine your file to find out what's going on. Do you want to post it?
...wow, just noticed I got no Kudos either. I'm really off my game on your thread.
