Hi
I have tweaked a Revit door family to be able to accommodate it for a low access to a plant room under a sloped beam
When i flex it to a height below 1800mm ... the 3d views look alright
But in plan view, one side of the frame doesn't look right ...
I have checked view range ... elevations views ... all are looking fine ... if i flex the height above 1800mm ... no problem
any thoughts ??? thank you so much in advance .. it drives me nuts !!
PS : i am only a few months old Revit user .. there may be something that i have missed ?
+files attached if usefull
Maria
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
FWIW, here's the official skinny:
