Simple Chamfer Command
craig
craig
New Revit user transitioning from Autocad where I;ve been comfortable for 30 years. Working in Autocad Architecture so 3D concepts are not new.
Is there a simple CHAMFER command to put a 50mm straight chamfer between 2 lines ??? Theres a FILLET > Radius and a TRIM> Corner but I can't seem to see or work our a simple 50mm chamfer between 2 lines without using the offset command, draw a new line and then do a trim on them ??? Am I missing the forest for the trees ????
No.  It takes a few more steps in Revit than in AutoCAD to do simple things like that.
Corsten.Au
Now am missing Chamfer command....it was one of the best command to use..
Revit should implement it in next update..
Corsten
Building Designer
craig
SERIOUSLY !!! This is what I'm finding that the simple drafting or drawing geometry is just so many more step. Thanks anyway
wrs
Community Visitor
Community Visitor
REVIT! Seriously.  No CHAMFER command!
syman2000
Keep voting Chamfer tools. Revit is overdue for 3d fillet/chamfer tools
https://forums.autodesk.com/t5/revit-ideas/chamfer-tool/idi-p/6321821
