Shows on my computer but not on hers...
5 ANTWORTEN 5
Nachricht 1 von 6
David125
294 Aufrufe, 5 Antworten
I created a door family, placed it on a wall. When my associate opens Revit file on her computer you can see wall cut but the door does not show. Any ideas for settings to check out?
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: David125
Check phase and workset.
Nachricht 3 von 6
David125
als Antwort auf: ToanDN
I did, it is quite bizarre. We are looking at the same room same view, on 2 different computers with 2 different appearances.
I also found out I can hover the mouse over the door and select it, it shows on properties dialog box as door that I placed.
By the way, I also made sure we were both starting with new local files. Just in case there was something corrupted on her file.
Nachricht 4 von 6
Sahay_R
Check the view templates and filters as well.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 5 von 6
David125
als Antwort auf: Sahay_R
Those show the same on my computer as well. We both removed local files, created new local files from the same central file. My assumption is that we should both see views exactly the same. Is there an option in Revit that is specific to each computer, controlling the display of a view?
Nachricht 6 von 6
Sahay_R
Any lost links? Look in Manage Links, see if all links are behaving themselves. Also - try to switch from Overlay to Attachment?
Rina Sahay
