showing linked models via linked view - Complex Plans
Hi All
I have a rather uncommon issue, on our set of floor plans, we show very large level changes (large concert halls) so we have many plan regions set up so the plan can read correctly showing the movement of people as per the design.
We are using a linked view setup where within our sheet model we link the geometry models so we avoid needing to have these plan regions in multiple views/ models.
However, the issue comes when we want to show structure within the drawing coming from the consultant model as structure within the sheet model is set to "by host View" and the required plan regions to make the view look correct are within the geometry models. I want to avoid linking the models within the geometry file by attachment as it slows the model too much as the worksets are not coordinated across the entire consultant team. We also have a lot of models as its a very large building.
I'm wondering is there is a solution to keep the models linked via overlay in all models, but get it to display in the sheet model as it does within the geometry file.
Thanks in advance!
