Showing Elements In View Which are Not
BigPicture045
Message 1 of 21
BigPicture045
Objective: Display double floor joist on residential crawl space plan.
Challenge: These double floor joist are located in the floor system which is not in the view range. Adjusting the view range for the double joist causes view issues with other elements (concrete block walls).
Known Workaround: 1) Create an individual plan region for each element (can look messy and is inconvenient). 2) Create non-true model which penetrates view region.
Desired Solution: Select element and click "Keep objected viewable in _____ level."
Is there any way to select an object and display it in a view without having to create a plan region?
Replies (20)
Message 21 of 21
Using Generic model is a proper solution. Generic models, casework, and windows show on plan even they are above the cut plane.
