Showing Dimensions in feet-inches-sixteenths (FIS) Format
5 REPLIES 5
eriS5ZWM
346 Views, 5 Replies
I have been trying to show dimensions for wall and truss shop drawings in
, but am unsure how to achieve this.
Any ideas?
Images for this format are attached.
Thanks!
Labels (1)
5 REPLIES 5
in reply to: eriS5ZWM
Not with dimensions but with a detail line based family.
Toan Nguyen
eriS5ZWM
Thank you!!!
eriS5ZWM
in reply to: ToanDN
@ToanDN , This is an excellent solution to applying F.I.S. dimensions, however I'm noticing there are limitations with this workaround. When I'm describing lengths greater than 6" in length, the "I" parameter assumes a negative integer value; ie. 2'-7" is processed as 3 feet and negative 5 inches.
Do you have an idea of how I can mitigate this?
Make this change.
Those brackets in the formula for S aren't needed.  I added them for clarity and forgot to take them out.
Toan Nguyen
eriS5ZWM
in reply to: ToanDN
You're amazing, thank you!
Forma Design Contest
Technology Administrators
