Say, I have a "Level 1 Code Compliance" Floor Plan view with Path to Travel visible on it. I want to show the same Path to Travel on "Level 1 Open Spaces" Floor Plan view and "Level 1 RCP" Reflected Ceiling Plan. Is it possible, if yes, How?
Thank you.
Duplicate the floor plan view, turn off everything except the paths of travel (isolate elements in view), duplicate it again as dependent, then place them in the same sheet of the other views.
