Show location map image on the ground floor
ara.donoBVVR8
ara.donoBVVR8
Is there a way were we can show  in one of the levels the map image from the location tool of manage tab in revit?
Instead of croping an image from google earth then inserting it as an image into revit's site level.
RDAOU
@ara.donoBVVR8
Hi ara, no there isn't such option. If you want you can post it as an idea on the Revit Ideas Forum
https://forums.autodesk.com/t5/revit-ideas/idb-p/302
ara.donoBVVR8
Thanks for the reply
ara.donoBVVR8
https://forums.autodesk.com/t5/revit-ideas/show-location-map-image-on-the-ground-floor/idi-p/1095891...
As @RDAOU suggested here is a solution idea added in autodesk ideas forum, so autodesk may consider integrating it in revit
