Show lights underneath objects
steadfasthomeplans
steadfasthomeplans
I am on the ceiling plan doing an electrical plan. When I put lights or fans into the plan, they end up underneath the bed, tub, sink etc. How do I make it so I can see both?
Bring the cut lane above the furniture then turn on Underlay so that you can see the furniture halftoned.
Set the Underlay Range: Base Level to the same Level of the ceiling plan; Range Tope Level = Level above; Orientation = Look down.
steadfasthomeplans
It worked! Thanks!
