Show Dash Lines when some part of a family is covered by Mask region
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
1731 Aufrufe, 9 Antworten
At elevation view, I saw a window family when some part of it is covered by masking region Revit shows that part by dash lines. how is it possible?
9 ANTWORTEN 9
Nachricht 2 von 10
David_Knight
als Antwort auf: Anonymous
I don't believe it is possible when covered with a mask region.
Nachricht 3 von 10
als Antwort auf: David_Knight
It is possible. please take a look at the screencast the masking region only works for this window family also it is the only making which can do this feature!
I totally confused.
Nachricht 4 von 10
David_Knight
Wow that's... pretty neat. I've never seen that before. I'll keep my eye on this thread to see if someone comes up with the answer.  I'd like to know too.
Nachricht 5 von 10
aRcHiTeCt.JM
.... wow ... this is crazy fun !!!!
... never ever saw something like this ....
Lachender SmileyLachender SmileyLachender Smiley
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Nachricht 6 von 10
David_Knight
als Antwort auf: aRcHiTeCt.JM
I wonder if a series of symbolic lines were drawn in the family.  Then they might show through a mask applied?  Would have thought that would have been masked too, but maybe there is a way to keep it in front?
Nachricht 7 von 10
FAIR59
This is accomplished using the Show-Hidden-Lines tool on the View-Tab.
  • activate command
  • first selection:  the masking region
  • second selection: the element you wish to show through the masking region.
Nachricht 8 von 10
aRcHiTeCt.JM
als Antwort auf: FAIR59
  • activate command
.... how ? ... I don't get it...
aRcHiTeCt.JM
REVIT EXPERT ELITE
Nachricht 9 von 10
thanks, FAIR59:
Go to view tab
1- select > show hidden lines
2- select > masking region
3-select > window
Nachricht 10 von 10
aRcHiTeCt.JM
@Anonymous wrote:
thanks, FAIR59:
Go to view tab
3-select > window
...... cool .... thanks ...
.... the more you know.....
aRcHiTeCt.JM
REVIT EXPERT ELITE
