Show cut pattern in Consistent Colors view
pdent1
pdent1
Hi. We have some section/elevations that I would like to show in Consistent Colors so that we can identify materials in wall areas beyond. The problem is that anything that is cut through, like concrete foundations, show in their "shading" color and not in the material cut pattern. Is there any way to change this? A global setting for cut items would be ideal but an "override by element" would work too (it's a small project). Thanks for any suggestions.
Material cut patterns show correctly in consistent colors views.
pdent1
Oh, you are right. Those patterns were turned off in the view template. Thanks.
