what do you mean? you can use bulb icon to select wall core to isolate or right click select all instances and hide in view or create a view template that only shows wall core and apply in other view if needed and see if helps. thanks
Isolate has issues. An I can't just select the cores.
I'm referring to Visibility graphics.
There's no way to hide everything but the wall core.
show some screenshot? thanks
That subcategory is useful only when the wall layers are conventionally split IN the Core and Outside the core. However, certain wall types need to have all the layers within the core (including finish layers) which makes that subcategory USELESS
It is possible to do that in a more efficient way using Parts + Filters
You might say that is too much work but we have those filters set up in out project template
I agree that it can be useless. I have another filter on this view, so core should be enough.
That being said, the core/outside core logic of walls, and the layer ordering is often one of the most frustrating/poorly thought out aspects of Revit. To get all intersections functioning properly for all walls and walls/roofs/floors is often not possible with the categories provided and the categories material layers find themselves often do not match their real world purpose.
Parts are useful and you are using them anyways. I personally prefer using these over that VG option which they added... check the solution for tagging as well as it is somewhat related to this post too
https://forums.autodesk.com/t5/revit-architecture-forum/tagging-original-of-parts/td-p/9759759
Yeah can't seem to create this.
I set the view to parts,
I create a filter that:
Applies to Parts
Category construction
does not equal core
I uncheck visibility
The fie was attached to your other port on Tagging...attaching here again. If all the wall layer are in the core, you would need to use either layer index or material ...
I don't have this subcategory in my walls (revit 2023) how do I add this?
Just found this searching for something else and wanted to comment, if you are a fan of Parts, you might want to check out PartsLab. its a free Revit addin at the app store https://apps.autodesk.com/RVT/Detail/Index?id=8116491063486271272
