AnzeigenĀ Ā nurĀ  | Stattdessen suchen nachĀ
Meintest du:Ā
shortcut creation
2 ANTWORTEN 2
Nachricht 1 von 3
steven
248 Aufrufe, 2 Antworten
shortcut creation
Is it possible to add one letter to a shortcut instead of 2, if i use one letter i see it will activate the command, but can not use it unless i push the enter  ?
reason why : i have a programmable keyboard who only allow one letter as a shortcut...
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: steven
Nachricht 3 von 3
RDAOU
That means you have assigned that letter to more than 1 command...in which case
-  you use arrow keys to select which command to execute
- and then you hit Enter or space bar to execute the selected
If you want that letter to execute without hitting enter, you need to make sure that the letter is assigned to only 1 command.
In Foren verƶffentlichen
