Working in elevation.
I've locked several dimensions between levels so that if I change one it shifts the locked leveles as well.
My issue is that when I lock these I can no longer shift these levels using dimensions, but the level height only. This is a pain as I have to calculate everything based on height from grade instead of just shifting things using measures I know offhand such as the height of my ceilings. Anyway around this?
btw I obv do not have the dimension I am trying to shift locked.
Just select "both" levels and use move instead...same result.
Steve Stafford
Maybe a level is pinned?
Steve Stafford
