Hello
I'm trying on dynamo to get total sheets number
Here where I have a problem (error), someone can help me on it please ?
Thnx
Gelöst! Gehe zur Lösung
Gelöst von J.Wehmer. Gehe zur Lösung
How about trying the Dynamo forum?
Hi @Anonymous
I got your message and looking at your script now.
Have you tried using a macro for this? How big is your model size and do you have many sheets?
As suggested by @RobDraw the dynamo forum will offer further feedback.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
You should get the end result using "List " or "Watch "
Hey i finish my last video and i talk about this , i hope its work for you.It this respond your cuestion click in solve that more people have beneficial for your question.
@ToanDN is right. you are providing a Family.Type into a Element.Type format. Dynamo does not recognize the data input.
If you need to apply a titleblock, that is a totally different node. The Element.SetParameterByName is only able to modify the parameters available to the sheets. The titleblock is not a parameter within the sheets, that is a family on the sheets.
Here is a simple way to renumber your sheets;
Keep experimenting and trying to change/add more data in your model using Dynamo!
