Sheet Template Identity Data
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
Stephen.Waters2C2VN
448 Aufrufe, 2 Antworten
I Have Designed By, Approved By, Drawn By & Checked By in my Title Block Properties. I'd like to delete Designed By & Approved By. Is this possible?
2 ANTWORTEN 2
Nachricht 2 von 3
Mike.FORM
als Antwort auf: Stephen.Waters2C2VN
Are you talking about a label that is showing this information in your titleblock or it is a parameter that you can fill in the properties when you select the titleblock?
If it is just the label then you can just edit the titleblock family and delete the label associated to drawn by and approved by.
The parameter itself however can not be removed as it is a built in project parameter.
Nachricht 3 von 3
Stephen.Waters2C2VN
als Antwort auf: Mike.FORM
It's a parameter that can be filled in in the properties. Thanks for this, I'll use the parameter and delete the label instead.
