Sheet Size D is not an option
1 ANTWORT 1
Nachricht 1 von 2
jmackniak
216 Aufrufe, 1 Antwort
Working with Revit 2022, trying to place work on a sheet size D.   When I select sheet from the view ribbon,  D is not available.   How do I add size D?
I do not need to print this, I simply need it to be on a sheet D for sharing.
1 ANTWORT 1
Nachricht 2 von 2
Revit_Whisperer
als Antwort auf: jmackniak
You will need to load one of the out of the box title blocks or create one and load it into your project, then it will be available when adding a new sheet
