Sheet Schedule with Revisions
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
KevinQ2WH2
669 Aufrufe, 4 Antworten
I am trying to figure out how to make a sheet schedule that shows what drawings were included in the revision sets. I have the schedule made with all of the required drawings.  We have multiple revisions coming and would like to indicate what drawings were included in each separate issue.
Please see the attached sample.
Thanks.
4 ANTWORTEN 4
Nachricht 2 von 5
vitorbortoncello
als Antwort auf: KevinQ2WH2
Select Current Revision and make sure to check revision on sheet
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 5
KevinQ2WH2
als Antwort auf: vitorbortoncello
I have done that, but it doesn't populate a list of past revisions, as shown in the screenshot I provided.
Nachricht 4 von 5
It cannot be done automatically.  You would need to add sheet parameters for each revision and tick Y/N box or enter the Dot character manually (sort sheet list by current revision so you can do it more easily), or semi-manually via Dynamo.
Nachricht 5 von 5
KevinQ2WH2
als Antwort auf: ToanDN
Thanks for your help with this, that is the information I was looking for.
